JTIS for Wheel bearing and lower front ball joint
Old Jul 24, 2013 | 11:00 PM
wotcham8's Avatar
Default JTIS for Wheel bearing and lower front ball joint
Hi,
While I'm trying to figure out how to download the JTIS on a mac, are there any guidelines in the JTIS for replacing the front right wheel bearing and lower ball joint?
If so, could someone please send them to me as a .pdf ?
I realize I will need to go to a machine shop to press in the lower front right ball joint. Am hoping the wheel bearing is something I can do myself. Any tips, photos or JTIS guidelines would be much appreciated.
Thanks,
Napoleon
Old Jul 25, 2013 | 03:43 AM
The PDF's are too big to post as attachments. I've put them on my MediaFire account for download:
Front Wheel Bearing:
http://www.mediafire.com/view/e63dbl...el_Bearing.pdf
Lower Arm:
http://www.mediafire.com/view/vqfbmj..._Lower_Arm.pdf
The bearing nut needs a special tool and a huge amount of force to remove it.
At least two members have successfully fabricated an equivalent from steel plate.
Old Jul 25, 2013 | 07:14 AM
wotcham8's Avatar
Thanks Graham, that's exactly what I was looking for.
Old Jul 25, 2013 | 07:56 AM
RaceDiagnostics's Avatar
The lower ball joint is just possible to do yourself but you will need a press or need to go to a shop to do the bearing.
Old Jul 25, 2013 | 09:38 AM
Paul Pavlik's Avatar
This shows part of the wheel bearing replacement:
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
