Jump start XK8
Old 11-06-2013, 04:10 AM
ArtyH's Avatar
Unhappy Jump start XK8
I have just read a thread about not using a second car to jump start a XK8 but to recharge the battery as the only way to proceed.
I did not know this at the time and about a month ago when I was getting my seats colour matched for repair, I had a flat battery on the XK8. I jumped it with my XJS, it started straight away. Now with the knowledge of possible damage to the sensitive electronics I was wondering if anyone could give me an idea of the kind of damage to look out for please? Looking for things to check which could have been damaged. Fingers crossed and everything else.
Old 11-06-2013, 04:58 AM
RaceDiagnostics's Avatar
I don't see why the XK8 should be any different to any other "modern" car for jump starting.
Does anyone have any evidence of "sensitive" electronics on this car that are poorly protected or is this just a myth.
So far, just about the only reliable thing on my car is the electronics!
Old 11-06-2013, 05:01 AM
GGG is offline
Received 16,818 Likes on 12,177 Posts
Arty,
The two things to avoid are:
1. running the engine of the 'jump' vehicle
2. allowing contact between the vehicles
The risk is a 'spike' which could fry the super sensitive electronics in the Jaguar.
I'm sure many owners have got away without any damage on numerous occasions but the risk is real. We had one member here within the last year who had serious issues with an Instrument Pack following a jump start.
If you had been unlucky when jump starting last month, you would be basking in the warm glow of warning lights or have dead functions and a catalogue of error codes by now.
Old 11-06-2013, 06:08 AM
Dennis07's Avatar
What GGG said. Just to flesh this out a little ...
1) If the car we're getting a jump from is running, and the jump is successful, then we will have the alternators and regulators of two running cars sort of fighting each other. Not so good.
2) Be sure ignition set to Off position (both cars) before attaching cables. Hook up the "hot" cable first, then the ground cable. The ground connection should be completed not at a battery, but somewhere with good frame contact away from a battery if possible. The last connection made should be the first one removed. The reason here is that the last connection may spark when connected /disconnected ... and a charging battery makes hydrogen ... and it's best to assure that the two never meet.
There's no reason not to jump start our cars (any car) so long as we're careful about how it's done.
Old 11-06-2013, 06:38 AM
WhiteXKR's Avatar
Received 2,982 Likes on 2,123 Posts
The other problem with jump starting is the proliferation of cheap jumper cables with wires that are not of a heavy enouh gauge to carry the starting current without excessive voltage drop.
This can cause the voltage during starting to dip so low that various computer modules begin to malfunction.. Usually a hard reset with a good battery will resolve any problems caused by this.
One way to avoid this is to have the donor car charge your battery first for say, 15-20 minutes, before attempting to start (assuming your battery is healthy enough to accept a charge).
Old 11-06-2013, 09:23 AM
Jon89's Avatar
Received 4,290 Likes on 2,818 Posts
I've jump-started many friends' vehicles over the decades without any issues. But if I ever have to jump-start either of our Jaguars, I'll do it strictly by the book due to the sensitive electronic modules. My biggest concern regarding this topic is that my wife's XK8 suddenly requires a jump-start during one of her trips to Florida and the AAA guy who shows up to do it refuses to follow the procedure as it is spelled out in the owners manual....
Old 11-06-2013, 02:44 PM
ArtyH's Avatar
Many thanks for all the comments guys, hopefully I have got away without causing any problems.
Cheers, ArtyH.
Old 11-06-2013, 03:57 PM
batroute's Avatar
Normally they will use a battery pack, not the battery on the recovery vehicle. Following on the post I have seen jumper cables advertised with inbuilt spike protection - Machine Mart in the U.K. used to sell them. How effective they are I don't know. What I do know is that I once jump started my BMW 7 series and fried the electronics - I'm very careful now
Old 11-07-2013, 05:57 AM
Dennis07's Avatar
Ouch! Sorry to hear.
Spikes and sparks tend to occur when a cable is removed (for the same reason a breaker-point ignition system fires when the points open).
Having both ignitions off when making or breaking jumper connections is a really good idea.
JarodL
03-07-2024 01:39 AM
99xk8guy
06-05-2023 06:28 AM
Bones
09-08-2015 08:34 PM
David Thompson
09-03-2015 07:48 PM
Quick Reply: Jump start XK8
