just did chains, etc
Old Feb 5, 2014 | 06:55 PM
stevepaa's Avatar
Default just did chains, etc
and now I hear a tapping noise that was not there before. ??
how do i load a video with the noise?
Old Feb 6, 2014 | 06:36 AM
ArtyH's Avatar
I'm going to do mine in the next few months weather permitting and have been swatting up on the subject. I'm no expert but a few things, did you take the pins out? Is the noise really bad, as there have been one or two members who stated the same and it was said to be normal due to the design of the newer metal part.
I'm sure someone with far more knowledge on the subject will guide you, just thought I would ask about the pins.
Good luck,
ArtyH
Old Feb 6, 2014 | 09:18 AM
stevepaa's Avatar
everthing was tight, pins removed. I suspect it is just valve noise that I could not hear before.
Old Feb 6, 2014 | 09:38 AM
dsnyder586's Avatar
Tick or tap? The injectors make a ticking noise. Might be a good idea to get a car stethoscope and listen around to be sure though.
Old Feb 6, 2014 | 10:40 AM
stevepaa's Avatar
tapping. sounds like the valves, but is loudest at the bottom of the engine
Old Feb 6, 2014 | 12:38 PM
stevepaa's Avatar
noise all gone this morning. the car sat idle for about a month while i was doing this
ran the engine for some time without the ignition relay. maybe it was not enough considering the time idle.
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
jonahjob
Oct 1, 2015 07:54 AM
JAMES1944
Sep 29, 2015 11:58 AM
