key fob i.d.
Old Mar 10, 2017 | 05:38 PM
dr.fixit's Avatar
Default key fob i.d.
I know that the key fobs are available on E Bay and that you have to match the the fob I.D. to that of the car. Is there some where on the car that has that I.D. number to match? Like on the case of the security system module? If so , where would it be located ?
Old Mar 10, 2017 | 07:04 PM
test point's Avatar
No.
For some model years there were at least two fob part numbers. I assume by your question that you do not have a functioning fob to replace or add. Best bet is to ask the nice person at a dealer parts counter to look up your build sheet by using the VIN. That is a great document anyway since it will have serial numbers for the engine and transmission and lots of info on the car as assembled. You may have to provide some verification of ownership such as a title to have access to that information.
Old Mar 10, 2017 | 09:18 PM
bcprice36's Avatar
Doc fixit;
Sorry but I'm not sure what you are asking? Do you want to program your Key-Fob so that your Jag will recognize it and lock/unlock the door or what?
Billy Clyde in Houston
Old Mar 10, 2017 | 09:35 PM
motorcarman's Avatar
1997 to 2000 XK8, 1998 to 2000 XJ8 (4.0 liter cars) uses one type of Keyfob Transmitter.
2001 onward (4.0 liter cars) uses a different one.
Old Mar 10, 2017 | 10:23 PM
Ungn's Avatar
If its a US car you need a LJA2610AA with an FCC id K8597T315
type either of those numbers into E-bay to see compatible remotes.
Sadly, the early cars don't do Ford Remotes or Flip Key Remotes.
