Knocking from rear when cold
Old Aug 20, 2025 | 04:56 AM
Wafoo's Avatar
Default Knocking from rear when cold
Have a knocking/clunking noise almost like metal on metal from rear when engine is cold, disappears after about 10 mins, its constant with wheel speed but only when decelerating , sounds like the half shaft is hitting something but can't see anything???
Old Aug 20, 2025 | 06:45 AM
JACKP's Avatar
Half shaft joint maybe.
Jack
Old Aug 20, 2025 | 07:35 AM
baxtor's Avatar
If only when cold, maybe over axle pipe and uni joint contact, heat creating clearance and pendulum effect of rear end on deceleration?
Check your hangers above diff pinion.
Old Aug 20, 2025 | 07:39 AM
zray's Avatar
The half-shafts have zerk grease fittings. Have they been attended to recently ?
Z
Old Aug 22, 2025 | 01:47 AM
Pistnbroke's Avatar
God is your wife still in the boot?
Old Aug 22, 2025 | 01:57 AM
Wafoo's Avatar
No, she's the high pitched squealing from the front...🤣
Old Aug 23, 2025 | 10:02 AM
Wafoo's Avatar
Well thankyou, popped Gerald on axle stands and had a look at the half shaft exhaust clearance, it was about 2mm, put a ty wrap on the exhaust and round the anti roll bar to see if I could get an extra 1mm on there, well job done, no noise, so put a new exhaust hanger on and jobs a good un as we say, thankyou 🙂
Han-S
19
May 2, 2025 06:10 AM
LedZepplin
Mar 22, 2022 02:36 AM
JOEOY
XF (X260)
Nov 25, 2021 11:24 AM
crateguy
Sep 27, 2021 05:56 PM
rclangelan
Jan 8, 2014 09:26 PM
