leak in radiator
Old Aug 5, 2012 | 12:18 PM
jam1white's Avatar
Unhappy leak in radiator
need ur help guys...whats good for stopping a hair line leak in my radiator?
Old Aug 5, 2012 | 12:41 PM
OregonJag's Avatar
What year is your car and how many miles?
If it's in the plastic tank and it's a high mileage or older XK you are ultimately looking at a replacement radiator If this is an emergency (you're stranded somewhere) I like Bars Leaks. But don't use any if you can help it because it gets into a lot of intricate places in these cars with heater hose octopuses, check valves, HVAC/engine coolant circulation pumps. It will eventually turn into a bigger headache.
I put an aftermarket Nissen brand in my '97 and it works much better than the old plugged up one.
Old Aug 5, 2012 | 12:47 PM
jam1white's Avatar
i have a 01XK8...yes it has a plastic radiator
Old Aug 5, 2012 | 01:22 PM
OregonJag's Avatar
The tanks on the end of the radiator are plastic; the core is metal. Didn't catch the mileage, but, take a look at this post I made a month ago-
https://www.jaguarforums.com/forum/x...ce-tech-76230/ (probably should make the radiator change its own thread).
It sort of touches on your current problem. It was what motivated me to change the radiator on mine. The plastic was just brittle. Do you know if it's the core or the tank that is leaking? Usually you can't get any long term fix for leaking plastic tanks.
Mike
Old Aug 8, 2012 | 09:17 AM
oldmots's Avatar
My fix for this is a new radiator. Not worth the risk of a fix that fails at a bad time. These plastic/aluminum radiators are BIC radiators...disposable.
willtoliv
Oct 2, 2015 12:18 PM
Blaine Trarop
Sep 23, 2015 03:08 PM
Tipptone
Sep 16, 2015 07:39 AM
1100me
Sep 7, 2015 06:26 AM
