Left wheel noise
Old Jan 26, 2014 | 01:56 PM
Spinedoc2304's Avatar
Default Left wheel noise
Hello to all!
On my new to me 1997 XK8 vert I hear a faint scraping sound coming out if the left front wheel only when making a right hand turn. At the beginning of the turn I don't hear anything but when the steering wheel has turned between 90-180 degrees you hear it. It only happens on right turns and only from the left wheel. Wheel bearings where replaced 15K miles ago.
I haven't had the opportunity to look yet.
Any ideas?
Nick
Old Jan 26, 2014 | 04:40 PM
bsprowls's Avatar
I once had the same symptoms on my 97. What I found was that disc brake shield had come loose at the bottom.
It is normally held on by a small clip (see #9 in the attached photo). If the clip comes loose it can cause the shield to scrape against rotor at certain turning angles.
A revision in later brake shields eliminated the lower clip & the shield is held more securely at the bottom by attaching to the lower ball joint bolt. I changed to the later shields when I rebuilt my whole front suspension.
Of course there are a whole lot of other things that may be causing the noise.
File Type: bmp
Old Jan 26, 2014 | 04:59 PM
Thanks for the info! Sounds like a simple fix. Next weekend it gets above freezing around here, I'll jack up the car and have a look.
Thanks again
Nick
Old Aug 5, 2014 | 03:37 AM
graham11's Avatar
Default wheel noise
maybe a small stone in between the disc and the wheel hub,this as happened to me twice once on each wheel sounds very similar
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
martybmw
Apr 2, 2016 04:55 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
