Lifters
What type of lifters does the 4.0 engine have. When mine is hot, I have a tapping noise on the right bank at idle. If I need to change it out, are special tools needed.....Thanks in advance.......Mike
you should take the valve cover off and check the type of tensioners on your car if they are the plastic type change them to the updated metal ones or you could lose your engine. it is not a hard job to do yourself using the zip tie method, you can find that in recent posts .good luck jrb 53
You got that right! I just got done rebuilding my heads along with metal HG's. I figure 234K miles it was due for an adjustment. It was VERY time consuming. I have seen 2 guys change out one shim before. Quite interesting.
If the clearance is within specification, but you are still having a tapping noise, there may be a sticking valve caused by carbon deposits on the back of the valve.
Refer to JTIS or the Workshop Manual for the correct procedure.
I could see valve train components, but haven't heard of this one before.
I had a ticking noise for years that I thought was coming from the valves, it turned out to be a cracked EGR flexi pipe.
I took the right valve cover off, and saw that the secondary adjuster had been changed once before. It was metal. I put a new one in, and the noise has gone away. I guess they wear out. Thanks for the help......Mike
There is a possibility that turning the engine in the opposite direction can cause damage to the bearing surfaces by the crankshaft.
Just curious, what led you to replace the tensioner? Did the shoe look crooked that the chain rode on??
direction with the valve train connected might be not so good for anything
beyond the crank gear.
But, I am still doubtful that it applies specifically to crank and rod bearings.
I am familiar with most of JTIS, but I looked again.
There are no cautions about direction of crank rotation in sections such
as valve adjustment, tensioner replacement, camshaft sprocket replacement
and even connecting rod bearing replacement.
If I remember correctly yours is the second replacement of the metal tensioners that has been reported on this forum.
Since the metal ones came out in '02 that is now 14 yeas and nothing lasts forever.
asleach2889
Mar 13, 2016 09:07 PM
