lights going off
Old Jan 8, 2013 | 01:08 PM
dennisw's Avatar
Lightbulb lights going off
as I pulled up at home tonight my head light went off and back on again.I think this has happend before but I dont drive a lot after dark.I confirm there is a problem as the drivers window lost its setting.checked battery lead and chassis earth all tight.new battery september 2012.
any help please
Old Jan 8, 2013 | 01:27 PM
steveinfrance's Avatar
It's usually the headlamp wiring in the steering column stalk.
JTIS is quite helpful here - start by removing the differential, transmission and engine then install them in a car with working headlights.
Seriously, though, try to reproduce the fault to see what is related to it.
Old Jan 9, 2013 | 11:03 AM
dennisw's Avatar
any more?
Old Jan 9, 2013 | 11:17 AM
SteveJacks's Avatar
Almost sounds like the issue Rev Sam had in this thread https://www.jaguarforums.com/forum/x...as-time-39893/
He had lights go off and window memory loss etc...
Old Jan 9, 2013 | 01:25 PM
dennisw's Avatar
Thanks for this post..very helpfull.I will have a go thursday a.m
will post any findings
Old Jan 10, 2013 | 08:28 AM
dennisw's Avatar
checked fuses in boot that go to battery..all tight.
no water ever been here..so back to square one....
Old Jan 10, 2013 | 12:43 PM
H20boy's Avatar
one headlight, or both together?
Old Jan 10, 2013 | 12:51 PM
dennisw's Avatar
both go out..for just a fraction of a second..then back on, happend a few times
thanks
Dennis
Old Jan 10, 2013 | 12:57 PM
SteveJacks's Avatar
Checked fuses - are you saying the ones that the big thick battery cable goes to behind the spare tire?
You don't mention that you checked the crimps on this thick cable which it turns out is what Rev Sam's issue was, not necessarily that the nuts were lose (which has also been found to be a problem), but check the crimps as it seems there was an issue with his and others causing these symptoms.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
