Little help with the gauge modification kit
Old Jun 24, 2012 | 04:54 PM
itspec60's Avatar
Default Little help with the gauge modification kit
Hi all, I'm installing my gauge kit from jagwrangler today and have hit a small problem. The right side harness calls to tap into a Pink/yellow wire. According to the JTIS for a 98 that would be a KY color code. The JTIS doesn't show that code for the right side connector. There is a purple/yellow on pin 3. Can anyone tell me which pin they used for the pink/yellow wire? Thanks
Old Jun 24, 2012 | 05:07 PM
WhiteXKR's Avatar
The pink/yellow wire should go to the purple/yellow wire on pin 3. Looks like I misread the 'P' color coding on the early model cars.
I'll get that corrected going forward. Thanks for pointing this out.
Old Jun 24, 2012 | 05:09 PM
itspec60's Avatar
Thanks for the quick reply...pin 3 it is.
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
Johncy2000
Oct 2, 2015 01:05 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
