Live wire
Old May 25, 2018 | 04:20 PM
Barry_Tucker's Avatar
Default Live wire
I have a bulb out in my gauge cluster ( Oil/clock/volt ) I will change it soon and would like to know if there is a convenient "always live" or "live when running" wire that I can tap into when I have the cluster out. I can't stand having the power cord for my sat nav trailing down over the gear lever to the cigarette lighter and would like to locate a power pint in the glove box or the area underneath it. Since I will have the cluster out it seems a good time to set this up. The wire should be able to carry sufficient current to charge the GPS
Old May 25, 2018 | 05:28 PM
The Jaguar solution is an Auxilliary Power Socket which can be installed in the glovebox and/or the luggage compartment.
Auxilliary Power Socket - C2A1403.pdf
No need to go to Jaguar for it. The equivalent parts are readily available.
Old May 25, 2018 | 09:18 PM
It says to "locate the auxiliary power connector" which appears to be behind the glove box. Does anybody know the colour of the connector or the wires ?
Old May 26, 2018 | 09:02 AM
toaster's Avatar
You can also use the power wire of the clock.......
Old May 26, 2018 | 09:32 AM
astromorg's Avatar
It's tucked up high on the outboard side of the glove box and you need to remove the glove box to get at it. The wires to it are Black - Ground, White/Red - switched live and Brown/Green - battery live. Standard insulated Lucar connectors fit the three blade connectors inside the main black body.
Old May 26, 2018 | 11:19 AM
Thanks ...I'll check it out when I replace the bulb
WaterDragon
Sep 2, 2013 04:41 PM
WaterDragon
Aug 29, 2013 02:38 PM
