Looking for a plenum (cowl) cover, part HJA3833AL...hmmmm...
Old Aug 6, 2013 | 01:07 PM
The Coupe's Avatar
Default Looking for a plenum (cowl) cover, part HJA3833AL...hmmmm...
Hello guys;
I'm looking for a new (or near new) plenum cover, sometimes referred to as the cowl cover. This is the long plastic piece along the base of the windshield...the wipers and washer jets come up through it.
My local dealer and Gaudin are both saying the part is not available. Any thoughts? I suppose I'll have to try and source something used...which may not look much better than the piece I've got. That's disappointing...this piece is highly visible and mine was cracked by a previous owner.
Let me know if you have any bright ideas, fellas. Part in question is labeled as number 1 in the diagram below.
Attached Thumbnails Looking for a plenum (cowl) cover, part HJA3833AL...hmmmm...-hja3833al_zps0f69b643.jpg
Old Aug 6, 2013 | 01:16 PM
jimbov8's Avatar
If they say they are unable to source one then try a breakers yard and then spray with satin black, or you might get lucky and find a good one.
Old Aug 6, 2013 | 01:30 PM
WhiteXKR's Avatar
Actually (at least on the earlier models) they were originally painted with Jaguar Dorchester Gray with a semi-gloss clear coat.
I have made invisible repairs in ABS plastic by reinforcing the repair from behind with scrap metal or plastic cemented with JB Weld. Once the repair sets, use a Dremel tool to grind out some material along the visible side of the crack. Then overfill the gap slightly with JB Weld. Once it sets, you can sand the area with progressively finer sandpaper to make the crack surface smooth. Then prime, lightly sand and paint.
Old Aug 6, 2013 | 01:56 PM
The Coupe's Avatar
Thank Steve-
Unfortunately, mine is missing a small 1" x 1" chunk where one of the screws are set at the base of the windshield. The flaw is semi-hidden beneath the left wiper, but I'd really like to replace the thing.
And you're right, mine is painted in Dorchester Grey.
Old Aug 6, 2013 | 03:06 PM
SeismicGuy's Avatar
I visited this car wrecking yard once or twice when I was looking for the ashtray insert on the 2005 XKR I had bought. They had a very good stock of all types of Jaguars, particularly XK8 and XKR. You might want to email them or give them a call:
These guys might have a new one: http://www.terrysjag.com/product/HJA3833AL.html
Doug
XJsc-guy
Sep 25, 2015 11:09 AM
Dicque
Sep 19, 2015 12:53 PM
KarimPA
Sep 12, 2015 08:15 AM
philwarner
Sep 6, 2015 11:10 PM
Dallas XK8
Sep 3, 2015 12:17 PM
