Loose headliner
Old May 31, 2017 | 07:05 AM
Mike Newby's Avatar
Default Loose headliner
My XK8 has loose headliner in a couple of places. Does anyone have any top tips on whether it is best to just replace it or can the original liner be stripped back and reglued?
Old May 31, 2017 | 07:13 AM
michaelh's Avatar
Default Coupe or Convertible?
Either way, the foam backing to the lining disintegrates, so it's generally a case of replacing the fabric.
M
Old May 31, 2017 | 01:31 PM
White Bear's Avatar
The Convertable is much easier to do than the Coupe.
Old May 31, 2017 | 06:38 PM
prettybluefin's Avatar
a new headliner is about $300, so it is probably worth replacing, especially since it will likely start falling in other places due to dried foam.
Old Jun 1, 2017 | 06:42 AM
kreyszig's Avatar
It's very easy to replace the fabric. Make sure you use a high temperature contact adhesive though.
