Low Coolant warning
Old Feb 21, 2024 | 01:42 PM
66RBS's Avatar
Default Low Coolant warning
This morning my 2003 XK8 displayed a low coolant warning for about 20 seconds about 15 seconds after startup
Went away and no further warnings
No apparent leaks and temp gauge reads normal
Coolant reservoir down about 6-8 oz.
I seem to recall the coolant sensors are troublesome.
Do I need worry? Replace the sensor?
Randy
Old Feb 21, 2024 | 02:18 PM
PDMiller's Avatar
Mine goes off about once a year and I always check it and top up with very small amount of coolant to get rid of the alarm. I wonder if the header tank is a bit small for such a big engine. If it keeps coming up and the level isn't dropping it might be worth changing the sensor.
Old Feb 22, 2024 | 03:08 AM
RichardS's Avatar
Randy
If you removed the top from the black header tank and the coolant was not full to the top then you have the classic XK8 issue that your atmospheric expansion tank is empty. In my experience, most XK8's cooling systems have not been filled correctly because garages and owners do not realise that the black coolant tank is not actually the main coolant reservoir.
There are many threads about this issue. I will post a link to the latest thread:
https://www.jaguarforums.com/forum/x...-empty-277527/
Richard
Phil m
Aug 1, 2022 12:59 PM
Just Another Guy
Jun 26, 2022 06:26 PM
bobg
Dec 6, 2012 04:04 PM
kblood
Dec 15, 2009 07:40 AM
chazaroo
Mar 2, 2009 11:37 PM
