Low voltage
Old Apr 19, 2018 | 08:04 AM
Emond's Avatar
Default Low voltage
I got a 98 xk8 that code read misfire cylinder 6. I installed a coil and all new plugs. It still read misfire on #6. So I switched #6 and #2 and I still read misfire on #6. I only have a text light so I hook it up to the coil leads and it did light up but not a bright as the other leads? So, would this be a problem coming from the ECM?
Old Apr 19, 2018 | 08:15 AM
avern1's Avatar
Sounds like a bad ground for the coil. One wire goes to ECM and one goes to ground. Follow the wire loom back to the ground point check it for cracks , kinks and corrosion
Old Apr 19, 2018 | 08:35 AM
Lady Penelope's Avatar
See page 35 upper right part of the diagram .
Can you easily swap the position of the ignition modules and see if the problem follows ?
All coils are powered by the ignition coil relay and the ECU provides the timed controlled ground through the ignition module ( new to me )
Inspect the wire connection on the suspect cylinder for a burnt pin and socket .
http://www.jagrepair.com/images/Auto.../jagxk1998.pdf
Old Apr 19, 2018 | 01:02 PM
Emond's Avatar
It must be a bad ground. Followed the lines up did a continuity test and seemed OK. Disconnected the battery for about 10mins. Held the negative and positive terminals together for about 10sec. And the bad cylinder reading with away. I didn't think I fixed the problem but it's working for now.
vettegood
May 5, 2018 07:57 PM
vettegood
May 31, 2017 06:26 AM
WldCat
Mar 3, 2012 03:33 PM
svldvc
Feb 12, 2011 01:46 AM
beckermj
Jul 21, 2010 09:38 PM
