Lower control Arm Bushings - What's the trick?
Old Jul 3, 2014 | 08:28 PM
Jandreu's Avatar
Default Lower control Arm Bushings - What's the trick?
03 XK8, replacing everything on the front suspension. Took my lower Control Arms to a machine shop to have the ball joints removed and pressed in, also wanted to replace the bushings. They got the bushings out on one arm, front and rear, but can't get the new ones back in. I did buy aftermarket parts and the shop claims they are to big.
I ordered new bushings, OEM, today but want to know if there is a trick to installing them before we try again. The shop completely destroyed one of the new ones, cut and extruded the rubber, trying to press it in. Might be because they were to big, I don't know but am looking for segestions before letting them have a go at it again.
Thanks,
Old Jul 3, 2014 | 08:35 PM
johns55's Avatar
I don't think there is anything special to the bushing install but I'm not sure. When I took the lower arm out, the bushings looked almost new. I ended up not replacing them and just doing the ball joints.
Old Jul 3, 2014 | 09:14 PM
Jandreu's Avatar
Wish I had done the same. Mine look OK also but as I bought the parts I figured why not use them. JITS says to just put a metal plate on top and press.
Old Jul 4, 2014 | 04:29 AM
RaceDiagnostics's Avatar
I pushed in these "Brit Parts" like this, but they were a very tight fit.
Old Jul 4, 2014 | 02:42 PM
H20boy's Avatar
what do they say...freeze the arm before putting them together? shrinks the metal, gives a bit more 'opening'?
Old Jul 4, 2014 | 02:49 PM
Jandreu's Avatar
I think it's freeze the bushing and heat the arm.
Old Jul 4, 2014 | 05:54 PM
dieseldoc's Avatar
Yes its freeze the bushing, heat the arm. Not a bad idea to use some sort of lubricant applied to both areas. Should be pressing on outer shell of bushing also.
GordoCatCar
Jan 2, 2017 01:10 PM
ym37tech
Feb 8, 2016 01:04 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
