Lowering Complete
Old May 9, 2011 | 02:11 PM
Paul Pavlik's Avatar
Default Lowering Complete
I had the Mina REAR Lowering Springs installed today at Jenkins Volvo-Jaguar (Milwaukee, Wi) and the results are very Satisfactory.
The height of the Rear Arch to Ground is now identical to the front dimension. The rear sits about 1.25" Lower than before.
The clearance between the top of the Tire and the Arch is actually 1/4" less at the Rear than at the Front now (but, of course, the rear tire is slightly greater in diameter than the Front).
The Ride Stiffness is Unchanged. The Mina Springs are "Progressive" and will stiffen at High Vehicle Loads.
Cost: Mina Rear (only) Springs. $250 inc. Shipping.
Labor: 4hr @ $115/hr----------- $460.
Total:----------------------------- $710
Before:
After:
Old May 9, 2011 | 02:16 PM
turbo68's Avatar
It was raining when I got home so I did not take Pics yet.
I Know!!! I will post pics ASAP.[/quote]
No fun if you add this to your posts... now what are we going to complain about???
Waiting for those pics!
Old May 9, 2011 | 05:07 PM
guzzi svt's Avatar
Looks right. I just lowered my rear. You should have put a pop can under the body front and back , before and after to get any idea how much it was lowered. New springs may sag a little as too.
Old May 9, 2011 | 10:52 PM
Fla Steve's Avatar
Looks great..now I want to do it..need to get a bunch of others projects finished first though.
Old May 9, 2011 | 10:56 PM
Fedoraja1's Avatar
If only I could find some cheap springs... but that's not high on my to-do list yet.
Old May 9, 2011 | 10:57 PM
Fedoraja1's Avatar
Looks great BTW!
Old May 10, 2011 | 01:25 AM
BeO's Avatar
BeO
Sweet, really really nice
Old May 10, 2011 | 02:18 AM
XKRacer's Avatar
Looks good, you wouldn't have a similar shot of before and after?
Old May 10, 2011 | 04:14 AM
Cadillac's Avatar
That's the modification indeed ,if I had an XK I would do the same too
Old May 10, 2011 | 02:45 PM
JRE-xkr's Avatar
The car sits perfect!
Old May 10, 2011 | 04:16 PM
guzzi svt's Avatar
Here are my before and after pics.
Attached Thumbnails Lowering Complete-before-lowering.jpg   Lowering Complete-after-lowering.jpg
Old May 10, 2011 | 06:44 PM
Looks good. What Springs did you use?
Old May 11, 2011 | 02:23 AM
Frog's Avatar
The before shot shows just how high US XKs ride. I may be wrong, but I think European models are more like the after shot straight out of the factory. Definitely a must-do mod.
Old May 11, 2011 | 02:43 AM
XKRacer's Avatar
All XKs look like they are up on stilts, it was only the later cars that looked a little lower, Jaguar never bothered doing anything about it, from what I understand it so the US guys can fit snow chains easier. It was one reason why Jaguar introduced CATS suspension, and what a PITA that is!
I lower XKs all the time, I have 2 in shop at moment I am doing, always a mod I would recommend to have done if only for appearance sake.
Old May 11, 2011 | 03:46 AM
guzzi svt's Avatar
Mine came off a Silverstone. Same hight as the Mina's the guy replaced them with.
I only put on the rears. I have a fully lowered Contour SVT and did want to deal with dragging the front end. It makes the car look level.
Old Jun 8, 2013 | 10:19 AM
philhef's Avatar
Old thread but I'm finishing my Arden kit this weekend and HAVE to lower the back. It actually makes the rear look even higher!! Actually the space between wheel and arch looks larger.
I assume that lowering the rear only will also lift the nose by the same amount, not the tire to arch space, just the nose. Believe me that's not an issue if it does due to the low front air dam addition. I actually hope it does!!
Old Jun 8, 2013 | 01:00 PM
Lowering the Rear will not change the Front.
Edit: Actually, lowering the Rear will "Pivot" the Front up by a Very Small amount.
Old Jun 8, 2013 | 06:07 PM
weisberg's Avatar
? Anyone who has done notice a meaningful difference for handling?
Old Jun 9, 2013 | 04:12 PM
philhef's Avatar
Hey, I'll take any pivot!! I've, in the first day, scraped the bottom of the front spoiler in my own driveway. Luckily underneath so it doesn't show. I've a lot of relearning how to drive it now to do!!
But who cares!! He's fierce!
Old Mar 7, 2016 | 09:50 AM
scardini1's Avatar
I was kinda thinking the same thing as Weisberg: Handling. Lowering just the rear looks fabulous, but a few new variables have been introduced.
I'm curious to see if you experience any front-end float at high speeds (or any sensation of float whatever).
Damn nice looking car, Paul.
