Lowering Springs choices
Old Dec 8, 2015 | 05:34 AM
jamdmyers's Avatar
Default Lowering Springs choices
I'm dropping the rear to replace bushings, while there I'm going to replace springs and shocks, I've decided to NOT go with CATS (yes I'll be replacing fronts also), I can't justify the cost so I'll 'pull the plug'. I feel a bit stiffer spring will offset the need for cats.
Question, Who's used what and your experience: I've looked at Arden/Amadesh and Mina
Old Dec 8, 2015 | 07:19 AM
ccfulton's Avatar
I have adamesh springs but they are not noticeably firmer than the originals.
I had replaced the fronts because the old springs were starting to sag. The lowering spring is actually higher than before. The rears I did just to bring the rear down a bit and moreover the look.
No problems at all and part of the reason for choosing adamesh was that they are one of the smaller height changes.
daro31
Canada
May 12, 2016 04:54 AM
skipro152
Nov 26, 2015 11:28 PM
quicksilvr20
Nov 20, 2015 09:10 PM
XxSlowpokexX
Nov 17, 2015 12:22 PM
Alexv12
Nov 12, 2015 03:05 PM
