Lube convertible latch mechanism - what to use?
Old Oct 23, 2017 | 06:48 PM
Jeff390's Avatar
Default Lube convertible latch mechanism - what to use?
Having just replace the hydraulic hoses to my latch, in putting it all together I thought it might be a good idea to lube the various latch and roof joints.
What sort of product should I use?
Cheers Jeff.
Old Oct 24, 2017 | 08:35 AM
Gus's Avatar
Gus
Use silicone on the ram shaft. I use WD40.
Old Oct 24, 2017 | 03:27 PM
Jeff390's Avatar
Thanks Gus. Do you mean you use WD40 on the latch mechanism and silicon on the rams?
Old Oct 24, 2017 | 04:24 PM
Gus's Avatar
Gus
WD40 stands for Water Displacement and the 40 stands for the number of attempts to make it right. I spray a little on my hands or rag and with the roof up i reach in between the roof and the roof liner and rub the ram/lift shaft with the lubricant then operate the roof a few times.
However, if you elect to use a silicone that would be ok. I do not force any products on anyone but I do like the cleaning and lubricating properties of WD40.
Old Oct 24, 2017 | 05:19 PM
Jeff390's Avatar
Thanks Gus. Will try a bit of WD40.
Old Oct 25, 2017 | 08:37 AM
OA5599's Avatar
Appreciate the info Gus, thanks!
Old Jul 3, 2022 | 06:52 AM
wss25's Avatar
I use WD 40 dry silicone. The key is to apply with q-tips in areas were the headliner or interior is nearby. Another method if you do not have time to do that is to spray a cloth and rub the surfaces with a cloth. In addition, get a good rubber treatment for the rails. I use 303 but there is a German product with a hard to pronounce name that is well accepted.
