Manc
Old Feb 27, 2016 | 05:58 PM
Manc's Avatar
Default Manc
I have a 2002 xk8 that will not start. When i turn the key, it makes a whirring noise but does not engage the engine.....any ideas please.
Old Feb 27, 2016 | 06:02 PM
avern1's Avatar
You need a new starter.
Old Feb 27, 2016 | 06:14 PM
Manc's Avatar
Default Starter
Thank you very much Vern. I was confused because when i parked it, it was ok then the following it would not start...... No warning
Old Feb 27, 2016 | 06:29 PM
RJ237's Avatar
Banging on the starter may free up the gear, but that's only a temporary fix. There are other things that quit suddenly, like fuel pumps.
Old Feb 28, 2016 | 01:13 AM
oyster's Avatar
Hi.
Are you absolutely sure the engine is not turning? Loss of compression due to what is called bore wash sounds sounds just like the starter not engaging.
Check at the front of the engine for rotation while cranking.
WhiteTardis
May 7, 2020 11:09 AM
mitcharon
Mar 20, 2016 11:57 AM
o2manyfish
Mar 5, 2016 10:44 PM
Amelorn
Feb 29, 2016 04:22 PM
mitcharon
Feb 24, 2016 05:52 AM
