MAP Sensor P0107 Fault
Old Jun 10, 2022 | 12:22 PM
jimejag's Avatar
Default MAP Sensor P0107 Fault
My 2001 XKR is throwing a P0107 code after doing a fairly major amount of work replacing the tensioners, heater hoses, etc.
The code was cleared but came back shortly afterwards. There are no other codes. My scanner shows a fixed pressure value while the engine is running. I replaced the sensor and the problem still exists.
I removed the plug and checked the voltage on the 3 pins, and found that I am reading ~ 5V between the ground pin and BOTH of the other pins. (See photos). Is this an indication of a bad ECU?
Left to Center Pin
Left to Right Pin
jimejag
Old Jun 14, 2022 | 07:02 PM
michaelh's Avatar
Jim - can you confirm that DTC?
P0107 shows as BARO circuit low voltage
Old Jun 15, 2022 | 05:21 PM
jimejag's Avatar
Default DTC Codes
Value does not change.
Old Jun 16, 2022 | 03:04 AM
dibbit's Avatar
So that is a P0105 not a P0107, but it is indeed the MAP sensor. There are a couple of other thing listed to check:-
To answer your specific question about reading 5V on the input pin to the ECU - I don't think that means anything as I doubt if that pin is left floating if unconnected and you are testing it with a high impedance multimeter - someone else might know differently as I have never tried this myself. I have always tested the other way, at the ECU harness connection to test wiring continuity to the sensor.
A better test would be to reconnect your MAP sensor and back probe the sensor connection/ground with your multimeter on volts and see if you get any kind of sensible value that changes with engine revs. Even better if you have a scanner that can show you live data from the MAP sensor - is that your second image?
And one last thing, a test lamp is a much better tool when checking for power & ground compared to a multimeter.
EsRay
May 15, 2024 12:56 PM
ferrral
Aug 13, 2021 04:11 PM
Ian Quintal
Nov 17, 2020 09:15 AM
Stumpygop
Jan 11, 2015 05:48 AM
pnfootitt
Sep 6, 2014 11:19 AM
