Missing roof tool
Old Nov 12, 2009 | 09:03 AM
mbalce's Avatar
Default Missing roof tool
I just wanted to put something back where it should be in case (knock on wood) I ever had a roof failure - that never happens on these cars though does it...
I peeked into the hole in the roof and stuck one of my tools in there. Appears to be a T40 Torx. Can anyone confirm?
I am sure if that is indeed what it is I can find a L shaped T40 that may even fit into the clips correctly (they are still there) cheaper than the $25 that the dealer wants.
Old Nov 12, 2009 | 10:01 AM
Gus's Avatar
Gus
I am not sure what size it is and never had a reason to measure it and not sure it is a T40. I do believe it is a metric allen wrench. I will check when I get a chance.
Old Nov 12, 2009 | 06:56 PM
Fjk's Avatar
Fjk
8 mm Hex....At least on an '04
Old Nov 12, 2009 | 07:39 PM
mbalce's Avatar
Ok, thanks! I had a large 8mm Hex in stock in the ole tool chest that fit right into the clips. Interesting - I did pop the little cover and confirmed it worked, which it did, but I shined a flashlight in there again and it really does look like a Torx and a T40 that I have in one of those fold out kits fits in and engages also.
Old Nov 13, 2009 | 05:46 PM
test point's Avatar
Never looked at the valve but the Jaguar tool is a simple 8mm Allen wrench.
danke
May 29, 2023 01:01 PM
duecedriver
Dec 25, 2015 11:47 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
Steve10
Sep 9, 2015 07:54 PM
nitrolouie2142
Sep 5, 2015 01:55 PM
