Mongoose and V134 software
Old Mar 30, 2014 | 08:34 AM
mctb's Avatar
Default Mongoose and V134 software
I have just got hold of a Mongoose from Singapore can with V134 software, but i seem to be having a problem that is common but there isnt really an answer out there there the problem
1. Software and licence load no problem on my XP laptop
2. Mongoose flashed up and is recognised by software
3. Enter VIN as mine is a 1997 XK8
4. Software states i must use Legacy IDS and gives me a button to transfer to it
5. Press button states load Legacy IDS then nothing it never appears
My question: is there a fix for this or do i need to try and get a early version of the software ie v130 (if i do anyone know of any links)
Old Mar 30, 2014 | 09:15 AM
ccfulton's Avatar
I also have v134 installed but never get a message about using Legacy IDS. Might be a difference is year of the car, as I have a 2003 model, which will also detect the VIN automatically.
I'm just guessing here but I found that removing the old Java Runtime and installing the latest version helped with the stability of the software.
Did your v134 come with the hack to stop it from needing an internet connection to work?
Old Mar 30, 2014 | 09:43 AM
mctb's Avatar
Ill try the update and see if that helps, i think the VIN recognition started on the 1999 update
Old Mar 30, 2014 | 10:24 AM
I'm also using v1.34 and Chinese Mongoose clone with no VIN recognition issues on my 2007 XK (I didn't have Mongoose when I was running either my 2001 or 2005 XK8's).
I think your model is too early for automatic VIN recognition. Have you tried entering it manually?
Old Mar 30, 2014 | 11:05 AM
mctb's Avatar
Yes i have tried a manual entry and it comes up with use Legacy IDS, i hit the button and its starts to download it but nothing happens it just goes back to the same screen
Old Mar 30, 2014 | 12:14 PM
Have you tried the IDS/SDD thread in General Tech Help for help and advice?
https://www.jaguarforums.com/forum/g...d-truth-32683/
Old Mar 30, 2014 | 01:28 PM
as well as asking your question you can spend a couple of days reading through it too.
JaguarLover101
48
Jun 12, 2023 10:28 AM
trosty
26
Dec 18, 2022 06:40 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
mrplow58
Sep 30, 2015 08:56 AM
