My XK8 cruise is not working.
Old Sep 24, 2014 | 09:34 AM
Fisch's Avatar
Default My XK8 cruise is not working.
Hi forum, when I switch cruise on, would engine one sec working very bad and after this- engine error- any experience with cruise repairing- what I must to look.
Thanks,
Fisch.
Old Sep 24, 2014 | 10:43 AM
Gus's Avatar
Gus
I would check your brake switch is is the most common problem.
Old Sep 29, 2014 | 04:40 PM
spuddyo's Avatar
The 97 cruise is vacuum controlled. I had a similar problem which was caused by a leak in a perished vacuum line. There are 3 valves mounted in the right hand side wing, which control the cruise. Check all the vacuum lines too and from this area, especially where they connect to the valves. Follow the vac tube from the throttle body along the firewall and into the Wing.
You need to remove the wheel arch covers to get access to the valves. Easy fix if you can find the leak. If that all seems ok, try the brake switch as the next option.
Old Sep 29, 2014 | 06:15 PM
RJ237's Avatar
Before taking the fender liner off, look for a vacuum line connection at the back right side of the engine (LHD?) coming out of the inlet manifold. The poor running is indication of a vacuum leak. Also check that the tube that connects to the dome on top of the throttle body is in place.
JCam
Oct 23, 2016 08:27 PM
Donzi
Sep 23, 2015 03:06 PM
Johnken
Sep 22, 2015 03:53 PM
avern1
Sep 8, 2015 06:25 PM
edtexas
Sep 4, 2015 08:20 PM
