Mystery Engine Number
Old May 17, 2011 | 03:08 PM
JagXK82001's Avatar
Default Mystery Engine Number
My owners manual says the engine number is located on a raised area around the thermostat housing.
I have crawled all over that engine several times and cannot locate any numbers. Took off the covers on both banks and cannot see any numbers.
Unless its under the intake manifold its not there.
Only number I see is on the back bank on the drivers side and its "NNE4400" which does not seem like an engine ID of any kind.
I have not jacked up the car to see if there is an ID on the bottom of the block as some have indicated on the forum.
Any suggestions??
My car is an 01 and was mfg in March of 01 according to the records. I am of course worried that my engine is one with the Nikasil Bores.
Old May 17, 2011 | 03:43 PM
test point's Avatar
Here is a link to the best description so far: https://www.jaguarforums.com/forum/x...31/#post346460
Look at post #9
The easiest answer is 'on the build sheet provided by a dealer using the VIN'.
Old May 17, 2011 | 04:21 PM
Spurlee's Avatar
Look at post #9
I took that sheet home an looked in both places it listed and could not see a serial number. And I mean I LOOKED. I can see where it's supposed to be, but there is nothing there...it must be buried underneath the housing for the T'stat.
Old May 17, 2011 | 04:26 PM
RCSign's Avatar
Jagxk82001
How's your engine running? Most Nikasil engines that have made it this far usually have no problems. The reason for the Nikasil problem was high sulfur content in some of the fuels in the later 90's and early 2000's Gus's web site has a very good article on Nikasil, and so does the sticky's.
The newer gas has lower amounts of sulfur, and not all of the fuels back during the 90's and 2000's had high sulfur content. One article I read attributed owners using cheaper non premium fuels in these engines. Porsche and several other manufacturers still use Nikasil coated blocks. Certain experts believe the Nikasil is plus over steel lined blocks. I have a Nikasil 2001 XKR with 80,000 miles on it and it runs like a top. Honestly I would not trade it for a steel lined block. Your car probably has the steel lines block, the cut off date was around August of 2000 the same time mine was built. but my engine was built in July of 2000, The engine # is hard to find go to your dealer and he should have the information. I was able to get all past service records and serial numbers of the major components. Good Luck
Old May 18, 2011 | 12:39 AM
avos's Avatar
Definately no nikasil anymore, engines build form September 2000 are cast iron sleeved.
philwarner
Oct 4, 2024 01:37 PM
Doug
Feb 27, 2019 01:31 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
