Mystery in need of solving
I was looking at my OBD Data on Fuel Trims and as I have said before, with installing the new purge valve the LTFT have gone up.
However, these high levels only show at idle, so here´s the 100 Dollars Question: What would tell the ECU in IDLE to pump more fuel to the system than under load?
Curious and Curiouser
If you have basic air leaks, they are usually best seen at idle because there is high vacuum and the leaks are likely a high percentage of the low air flow going in. At high rpm, the high air flow may mask the air leaks.
Have you tried a smoke test through the exhaust? This would detect exhaust gasket leaks, as well as leaks in the EGR tube (pretty common) if you have one.
Jagples
Jun 18, 2019 07:05 PM
Jagples
May 16, 2012 02:34 AM
jmalagon42
Jan 25, 2011 07:21 PM
