Mystery sound
Old Dec 31, 2021 | 02:35 PM
olphart's Avatar
Question Mystery sound
Got Pandora's cam cover back on and started it up to listen to the noises and locate the issue. this is what I heard. Any ideas?
Old Dec 31, 2021 | 03:26 PM
Pistnbroke's Avatar
Take the aux belt off and see if you still got it
Old Jan 1, 2022 | 07:42 AM
STLTHMSTA's Avatar
Sounds like a bearing from what I can tell from the video. I agree with the belt idea as the first step to isolate and locate. TM
Old Jan 1, 2022 | 07:50 AM
Gus's Avatar
Gus
See if this helps to identify the problem.
JagRepair.com - Jaguar Repair Information Resource
Gus
Old Jan 3, 2022 | 09:52 AM
Dickiederson's Avatar
Can you find where the noise is coming from?
I'm chasing a similar sound... at first I assumed it was belt related but when I get under the car it seems like it's more focussed around the bell housing and torque converter
Old Jan 3, 2022 | 03:12 PM
Pistnbroke's Avatar
I have the same sound as Dickerson but it is not like the one in the OP recording.
Old Jan 23, 2022 | 07:23 PM
olphart's Avatar
Haven't had a chance to chase it down yet. Way too cold in my garage, but the idlers/belt sound like a good bet.
Old Jan 24, 2022 | 02:09 AM
Pistnbroke's Avatar
You need a mechanics stethoscope to check the idler bearings only about £5 ..invaluable
ebay.co.uk/ item/255051085509 just put the number in the search box
Old Jan 24, 2022 | 05:24 AM
olphart's Avatar
Been there, done that. The results were pretty inconclusive other than the sound was coming from that general area. Found out what sticking a probe onto a spinning part sounds like up really close!
Old Jan 24, 2022 | 06:03 AM
Pistnbroke's Avatar
sorry dont follow that ..you put it on the bearingshaft and you can hear the rumble in the bearing if it has any ..you dont touch rotating parts just the casing etc.
Old Jan 24, 2022 | 09:29 AM
michaelh's Avatar
LOL - I had to be careful to keep my hair away back in the day. Not so much of an issue now
Old Jan 25, 2022 | 11:25 AM
Jerry Lippmann's Avatar
I was chasing a similar noise, in the lower front right side, after replacing idler pulley, tensioner, and belt. I noodled around with a poor man's stethoscope - a 3/8" hose, one end in my ear and one poking around for noise. Easily isolated to alternator. I had a spare so the choice to replace was easy. A few minutes later I found the bottom bolt loose - no nut at all, and the top bolt missing altogether. I guess the belt tension was holding everything in place until I upset the system by removing and replacing the belt/pulley/tensioner.
DPO (or his mechanic) must have gotten in there and given up on what seemed a difficult R&R. One year ago I found a similar approach applied to the heater pump: things partially taken apart and decided to stop when it seemed to difficult. I finished it, not opposed to difficult jobs myself, and am now poking around for my next surprise.
All the best,
Jerry Lippmann
1999 XK8 156Kmi
justinw
Aug 10, 2021 09:13 PM
Misujerr
Jun 25, 2017 02:10 PM
Z07Brandon
Jun 16, 2017 08:22 AM
Mike V
Jun 22, 2012 12:59 AM
