Need basic help '99 XK8 possible fuel leak
Old Jan 9, 2011 | 11:31 PM
midamdoc's Avatar
Default Need basic help '99 XK8 possible fuel leak
1999 XK8 conv 84kmiles, bought 2 mos ago California left side driver, drives great. about once a week I get strong fuel smell in cabin, seems like fuel guage goes down rapidly but I don't see any leak or smoke anywhere. Any ideas?
Old Jan 9, 2011 | 11:48 PM
midamdoc's Avatar
Also have gotten OBDII code for evap system leak; dealer said it was gas cap; replaced; same code reappeared 2 wks later. no more codes since i close cap very tight but still get fuel smell and suspected leak problem once a week. Hope for reply from Brutal, or any tech.
Old Jan 10, 2011 | 02:08 AM
H20boy's Avatar
this is quite common, as a matter of fact, mine had the same leak.
Often, it is a partially open/closed cannister close valve. On my car, the fuel vent line rusted, dropping pieces into the CCV, causing it to stay open and give the code for the leak.
Others have just replaced the cannister and left the vent tube, I had both changed so as to prevent it from happening again sooner.
if you search the xk8 area, you'll see a few threads recently about it, with locations and how its changed. gluck!
toronadomike
Jan 22, 2026 10:13 PM
Bcrary3
Feb 21, 2023 04:29 AM
kelliott
May 31, 2022 05:26 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
