Need part xk8 2005
Old Mar 31, 2012 | 09:56 AM
XK82005's Avatar
Default Need part xk8 2005
Looking for the chrome triangle next to the headlamp.
on a 2005 XK 8.
any ideas?
JB
2005 XK8
Old Mar 31, 2012 | 10:09 AM
on a 2005 XK 8.
any ideas?
JB
2005 XK8
This one bottom centre in the headlamp shell?
Depends on whether you have powerwash or not. It's a clip on cover for the headlamp washer or a blank for non powerwash.
Old Mar 31, 2012 | 11:11 AM
XK82005's Avatar
Default Headlamp washer cover
Graham,
I am not sure.
I donot have lamp washers, but I have water squirting from that hole.
Does blank cover also plug hose for windscreen washers?
Old Mar 31, 2012 | 01:17 PM
NikasilNik's Avatar
If you have water squirting from that point you must have headlamp washers , plus if that section is missing it's the cover for the washers ,
on a non washer headlamp that part is moulded as one piece to the glass lens and is a integral part ,
Hope this helps ,
Nik
Old Mar 31, 2012 | 01:32 PM
You need to determine exactly what is fitted and what is missing. The headlamp powerwash components are:
Jaguar XK8 - Headlamp Powerwash.pdf
Rather than repair them, owners often disconnect the feed pipe or remove it entirely when the wash unit fails.
WhiteXKR's Avatar
Hope this helps ,
Nik
Part #, LJA7055FA left,
LJA7054FA right
Jaguar Parts - Direct JPLV Porsche Parts.com
Old May 16, 2014 | 05:27 PM
Arland Green's Avatar
Hope this helps ,
Nik
Does this mean if I have a cover that can pop off on a pot hole that I must have the lens washer system on a 2005 XKR, since it is not integrally moulded to the headlamp lens? Do you know how it is attached? Do you just push it in, or is it glued or what?
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
KarimPA
Sep 12, 2015 08:15 AM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
