Need Radio Code please
Old Sep 7, 2021 | 12:30 PM
Markmbaha1's Avatar
Default Need Radio Code please
Apparently if the battery is disconnected I need a code for the radio to somehow reactivate it? I do not have an owners manual so that option is out. How else could I go about getting that code. I am assuming the same thing would happen if the battery went dead. Anyone who can help to get the code is greatly appreciated. Thank you
Mark
Old Sep 7, 2021 | 04:04 PM
fmertz's Avatar
Easy answer is the dealer. Check with them to see what they need, likely a VIN and possibly a visit in person or proof or ownership.
There are online services that claim to have these codes available (for a fee), sometimes even for radios that need no code at all!
It is generally understood that most (but not all) factory radios in the US have no code. In the UK, most seem to need a code.
Finally, there are techniques you can use to avoid disconnecting power while swapping batteries. I believe battery service people generally do this to avoid resetting emission monitors, window stops and tripping radio codes.
Old Sep 7, 2021 | 05:53 PM
Markmbaha1's Avatar
Thank you. Mine is US. I guess there is no way to check, without possibly shutting it off.
thank you
Mark
Old Sep 7, 2021 | 06:35 PM
Nickel's Avatar
Mark, Many on the forum here in the US have reported not needing a code. I had my battery disconnected for 2 weeks last month, and radio came back to life without a code.
Old Sep 8, 2021 | 02:29 AM
+1 to the above
Coded radios were STANDARD in the EUROPEAN market but are very RARE in the US market. There was a massive problem with radio theft in the UK in the 80's and 90's and this was introduced as a deterrent.
If you are very unfortunate and do have a coded radio, any JLR dealer can lookup the code using the VIN. Several online sources on the likes of ebay claim to be able to lookup the codes but success is reported as variable.
For completeness, here is the extract from the Audio Handbook about the security code:
If you need HANDBOOKS, the full sets are available for download in this thread:
https://www.jaguarforums.com/forum/x...006-faq-67827/
Old Sep 8, 2021 | 08:39 AM
Markmbaha1's Avatar
Originally Posted by GGG
+1 to the above
Thank you so much Grahm. I did not receive any manuals or guides with the used purchase so I'll check out that link when I get hone as well.
mark
TropicCat
Jul 13, 2021 10:51 AM
xtype62
May 12, 2016 01:06 PM
jaguarlady03
May 17, 2013 03:09 PM
JagHag36
Sep 23, 2011 08:54 AM
Reverend Sam
Sep 11, 2010 12:31 AM
