Need to replace 1997 XK8 stereo
Old Apr 5, 2014 | 04:07 PM
trebor2468's Avatar
Default Need to replace 1997 XK8 stereo
Can anyone direct me to instructions for removing and replacing the face plate and stereo in a 1997 XK8 coup?
Old Apr 5, 2014 | 05:56 PM
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 5, 2014 | 08:26 PM
01Silverstone's Avatar
Being that its a '97, you could have an easier job than the rest of us. Throughout the production of the X100, Jaguar used 2 different radios and thus 2 different bezels. The early 97 cars used a radio with an (almost) standard single DIN opening, and the rest used a non-standard radio size.
So the first step will be determining which one your car is fitted with (see the pictures below).
If it's the original style (Image 1), you're lucky and only need a faceplate adapter manufactured by Nexxia (Image 3). Once fitting this into your existing bezel, any single DIN replacement will fit. The second picture requires some modification before fitting the new radio.
If you do indeed have the newer style (Image 2), there are a couple options depending on how handy you are. You can fabricate your own surround piece if you feel comfortable, or there are 2 parts you can purchase that will make a single-DIN radio fit. The first is the same Nexxia adapter as above, and the second is Jaguar part #LJA6318AB (Image 4), which is the bezel surround from earlier cars as seen in the first photo. This will replace your existing bezel surround. Image 5 is the bezel you need and nexxia adapter fitted together.
No matter which radio you have, your opening will need to look like Image 5 before going forward with a new radio. It's just a matter of whether or not you need the new bezel or not (Jaguar part #LJA6318AB, Iamge 4).
To recap. Image 1 is old style radio. Image 2 is new style radio, Image 3 is the Nexxia adapter you need no matter what. Image 4 is the bezel you already have with the old style radio, or the one you need to acquire if you have the new one. Image 5 is the bezel and Nexxia adapter fitted together.
Hope that's not too confusing...
Attached Thumbnails Need to replace 1997 XK8 stereo-original-radio.png   Need to replace 1997 XK8 stereo-new-style-radio.jpeg   Need to replace 1997 XK8 stereo-nexxia-adapter.jpeg   Need to replace 1997 XK8 stereo-jaguar-part-lja6318ab.png   Need to replace 1997 XK8 stereo-bezel-surround-nexxia-adapter.png
Old Apr 6, 2014 | 06:20 PM
smoggyx100's Avatar
To add to silverstones excellent answer. This link may help.
https://www.jaguarforums.com/forum/x...ontrols-56937/
Old Nov 17, 2015 | 04:52 PM
Tintenbar's Avatar
Thank you Silverstone. My problem is that despite three e-mails to Nexxia in the UK I have had no reply re the required faceplate adapter. I think the part in question is FP-14-00. I wonder if they don't supply to Australia? Thank you in particular for the Jaguar part number. Tintenbar
Old Nov 5, 2025 | 11:08 AM
AbnMike's Avatar
It was for me, but that's because I'm probably slow.
Hoping you're still around despite a very old thread.
I have a 1999 - so the newer style bezel/surround. It's broken to bits. Based on what I am reading it seems that I could acquire the earlier bezel (widely found and available) and match it with that nexxia adapter, and it would work in my 1999?
Or am I reading it wrong?
Because that is infinitely easier than trying to find the LJB6318AB bezel!
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
