Need to replace cracked shift indicator
Old May 9, 2017 | 06:14 PM
dbunt101's Avatar
Default Need to replace cracked shift indicator
Looking to replace a cracked shift indicator plastic piece. It indicates what gear you are in....black with white lettering. I just purchased a 2002 xkr and need a few cosmetic repairs to make it look outstanding....really excited...this forum is awesome....packed with knowledge. I could also use references to find new and used parts without getting whacked at the dealer. Thank You Gentlemen and Ladies probably.
Old May 9, 2017 | 06:38 PM
dsd's Avatar
dsd
From Jaguar, that part is not an individual component and the set is like $550. Used 5 speed gates are available much cheaper and occasionally you can even find just that part on eBay.
That said, there is an aluminum one found on eBay for around $65.
https://www.ebay.com/itm/302281676758
Check forum sponsors for parts sources. They are all good.
Old May 9, 2017 | 06:46 PM
dbunt101's Avatar
Thanks for the reply...ebay..yes..$425 plus. The aluminum one....got it. Looks better than the original I think. Willorde today. Awesome !
Old May 9, 2017 | 06:50 PM
dsd's Avatar
dsd
Originally Posted by dbunt101
Thanks for the reply...ebay..yes..$425 plus. The aluminum one....no offer found on ebay...can you help locate it. Used is ok...got a parts site for one ?
The Aluminum is eBay item 302281676758. It looks like he had 7 available.
eBay has a ton of gates. Search "xk8 gear -knob"
Old May 9, 2017 | 06:53 PM
dsd's Avatar
dsd
Screenshot...
Old Nov 21, 2024 | 10:11 AM
ndaviesgeo's Avatar
Hi
I also have a cracked gear selector trim plate (the plastic face plate with PRND, 5432). i have searched ebay and don't see the stainless version any more. Looking for either plastic or stainless. Anybody have a recent source?
Thanks!
Old Nov 21, 2024 | 10:18 AM
KC XK8's Avatar
Default Following as I also have a cracked one.
Originally Posted by ndaviesgeo
Hi
Thanks!
Mine is cracked as well and I am also looking for a replacement.
Old Nov 22, 2024 | 07:59 AM
Zspot's Avatar
@QDavidP Found this from a 3D Printer in France.
https://www.gryp-3d.com/gb/jaguar-xk...te-finish.html
He’s posted that it works well and the install was easy. I need one too but haven’t pulled the trigger. I’m speaking with some 3D printers in my area to replicate, but their set up fees to build the model are way too high. So I may just go this way too.
Old Nov 22, 2024 | 08:32 AM
ndaviesgeo's Avatar
Thank you! that's certainly an option, but a little pricey for what it is. I found this one:
https://modulemaster.com/products/jaguar-xj6-xj8-s-type-x-type-shifter-indicator-illumination-upgrade-rebuild
but what i talked to them, they are really only fixing the illumination using your old parts.
I have found some stock plastic/HDPE that is a good match adn I am going to take a shot at fabricating my own..........but I am not sure how it will turn out. if i have success, I will report back.
Cheers!
Jag-man
Sep 19, 2023 11:46 PM
xj8z
Dec 9, 2014 04:32 PM
Norrie1
Jul 20, 2013 10:25 AM
2000JagLvr
Interior
Nov 12, 2012 06:40 PM
mariela128
Jan 18, 2011 10:41 AM
