New front springs, shocks, mounts, the works.....lots of photos
Old Aug 4, 2014 | 10:36 PM
Jag#4's Avatar
Originally Posted by JohnT
Maybe a silly question, but given the second picture in the original post which seems to show you can disassemble the upper front shock mount, has anyone tried to find a source that would allow us to just replace the shrinking doughnut, rather than the complete upper mount?
Actually several has successfully replaced only the doughnut section. The doughnut is a separate piece even in the OEM version, so once disassembled it is just a swap out with the right material.
Search the threads. One or two that show how to do this.
Old Aug 4, 2014 | 11:38 PM
JohnT's Avatar
Mike,
Many thanks for rectifying the failure on my side to search hard enough!
Some interesting alternatives - and thanks for documenting your version so clearly.
If anyone wants a shortcut to more info, here are the threads I found most relevant (there are probably more!)
https://www.jaguarforums.com/forum/xk8-xkr-17/$6-00-front-shock-mount-fix-83608/
https://www.jaguarforums.com/forum/x...spacer-104129/
https://www.jaguarforums.com/forum/x...0-bucks-77884/
https://www.jaguarforums.com/forum/x...-mounts-61066/
Old Oct 31, 2016 | 08:11 AM
hemitwist's Avatar
[QUOTE=JohnT;1029727]Some flavour of this project is almost certainly on my future action plan, so I've been reading all the posts with interest!
Maybe a silly question, but given the second picture in the original post which seems to show you can disassemble the upper front shock mount, has anyone tried to find a source that would allow us to just replace the shrinking doughnut, rather than the complete upper mount? I assume that others have had the same thought, and either failed to find a vendor, or discarded the idea for reasons that I am probably about to be enlightened with![/QUOTE
Here you go. Try Motorcars LTD for the parts you had asked for. NOT! You rebuild the upper shock mounts yourself. They did not last me 10,000 miles. I paid quite a bit for what I had got from them years ago.
https://www.jaguarforums.com/forum/at...hockmounts.jpg
I thought that the wife had tar on the lower side of car. LTD Motorcars upper shock mounts
Side by side LTD upper shock mounts.
This was the good LTD upper shock mount lol
Old Feb 18, 2017 | 09:37 AM
Letmyhairfly's Avatar
Simply perfect. Exactly waht I needed to see as I am rebuilding my front suspension on 98 Xk8. Thank you !!! I see your in SC. If near Lake Hartwell, drive over one day and lets have a beer.
Old Feb 18, 2017 | 08:43 PM
Cabel's Avatar
When the time comes for my bushings I'm doing this -
Old Feb 21, 2017 | 08:48 PM
PatB's Avatar
Thanks to The Coupe. Great job documenting your project. Very helpful.
Old Apr 12, 2017 | 01:22 AM
lossking_'s Avatar
Think those shocks would work on a xkr? I could care less about cats
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
