New lug nuts for 2000 XK8, will these work?
Old Nov 20, 2011 | 04:46 PM
jagosaurus's Avatar
Question New lug nuts for 2000 XK8, will these work?
20 Chrome lug nuts for $17
The original nuts have covers that tend to fall off, especially after being serviced by a mechanic..
Cheers!
Old Nov 20, 2011 | 07:06 PM
MRomanik's Avatar
Veteran: Air Force
From the sellers description, it sounds like they will only work with ET wheels.
Old Nov 20, 2011 | 07:46 PM
test point's Avatar
After an exhaustive search for new lug bolts I found none that would properly fit the XK8/R wheels. Ended up removing the steel covers, polishing them with a buffing wheel and epoxying them back on the actual nuts.
Old Nov 20, 2011 | 07:55 PM
jagosaurus's Avatar
I see, so can you remove the the nuts with the covers epoxied onto them? I guess Nally might have the covers?
Seems like ET is not what I want, but these look right: http://www.ebay.com/itm/20-JAGUAR-XK...ht_2884wt_1396
Otherwise the OEMs go for 6 bucks a piece from auto parts warehouse (but don't look as good).
Old Nov 20, 2011 | 10:15 PM
test point's Avatar
The covers are not sold separately and are polished stainless steel rather than chrome plated. The covers were not intended to be removed but can be pressed off easily by inserting a small piece of 3/8" wood dowel in the nut and running it onto the stud or by an 18 year old tire jockey with a 500 foot pound air wrench.
Eight dollars was the cheapest I found a couple years ago ($8 x 20 = $160) . . . for lug nuts!
Old Nov 20, 2011 | 10:19 PM
jagosaurus's Avatar
Ok, I'll have to talk to my dear mechanic and see if he has found them. Bah!
Old Nov 21, 2011 | 02:07 AM
XKRacer's Avatar
I can do a set for $100 not sure what the delivery cost would be, I dont have any in stock at the moment but can get them easy enough, they are not OE but look exactly the same.
I dont normally have to buy them as I have dozens laying around from putting on after market wheels, most of them use cone nuts.
The nuts shown on ebay will not be any good for an XK even though they advertise as so.
Old Nov 21, 2011 | 02:40 AM
pomosv's Avatar
No, they won't fit. It's not so much the thread size as the unique profile jag uses. The ones you posted have the common acorn style profile, Jag wheels require the flat profile:
Check out this thread:
https://www.jaguarforums.com/forum/w...ug-nuts-61319/
Old Nov 21, 2011 | 06:18 AM
You'll also find extensive discussion of lug nuts in the S type section if you're interested.
Here's a couple of options.
https://www.jaguarforums.com/forum/s...ug-nuts-39335/
https://www.jaguarforums.com/forum/s...e-again-52181/
Old Nov 21, 2011 | 06:26 AM
Max's Avatar
Max
Last fall I priced a complete set of lug nuts for our '02 Chrysler T&C and they were $5 each X 20 = $100. So, as has been said numerous times before, "The nicer things in life cost a bit more".
Old Nov 21, 2011 | 08:21 AM
The Coupe's Avatar
Had a good laugh at that one.
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
XJsc-guy
Sep 2, 2015 11:43 AM
