new oil drip from the front
Old 04-27-2012, 03:00 PM
RaceDiagnostics's Avatar
Default new oil drip from the front
I noticed some new oil spots on the drive today. Is this an engine oil cooler or transmission fluid cooler?
Do they typically start to leak?
Can the pipes enetring the top be tightened?
Can they be repaired?
I lifted the car a week ago using the front cross member, could this have disturbed it?
Old 04-27-2012, 03:48 PM
WhiteXKR's Avatar
Received 2,983 Likes on 2,124 Posts
That is your engine oil cooler.
Old 04-27-2012, 03:56 PM
The Coupe's Avatar
It's funny...and truly no disrespect here...I'm learning things about my beloved coupe every day.
But when I've seen your forum name in other posts...RaceDiagnostics...I thought to myself "oh good, we've got another pro here...we can always use new pros on the forum."
But then you've got basic questions, just like everyone else! Oh well. Glad you're in the group and we'll all help in any way we can.
Old 04-27-2012, 06:01 PM
GGG is offline
Received 16,835 Likes on 12,182 Posts
.........and that black fluid on the floor is engine oil.
Old 04-28-2012, 01:32 PM
Kick a man when he is down ehh.
I was snowboarding all day today so didn't get under the car yet but will get a better look tomorrow.
Whats with the lobe on the connection to the pipe, does it have any purpose, and is there a nut on top of that lobe.
Cairngorm in Scotland today.
Old 04-28-2012, 02:10 PM
GGG is offline
Out there enjoying yourself and you want sympathy!
Looks like a great day.
The parts diagram makes the layout a bit clearer:
1999 XK8 - Oil Cooler & Pipes.pdf
Could be a pipe gone but may just be an O ring. you're going to have to clean it off to see exactly where it's leaking.
Old 04-28-2012, 02:39 PM
I also found a parts list diagram for the later cars, from that it looks like the pipe is just pushed in with an o ring, I'm assuming the lobe is some kind of locking mechanism.
Old 04-28-2012, 05:36 PM
GGG is offline
The pipes are secured with flange headed screws through the lobes on the 4.2 ltr.
Old 04-29-2012, 10:15 AM
Cleaned it up this morning and found the source of the leak, will need to be repllaced.
bamforp
09-26-2021 08:04 AM
giandanielxk8
09-06-2015 07:21 PM
Dymaxxion
09-04-2015 02:40 PM
bdboyle
09-04-2015 06:16 AM
Jag-o-nomic
09-04-2015 03:07 AM
Quick Reply: new oil drip from the front
