new rebuilt 5hp24 gearbox flaring between 2nd and 3rd gear
Old Feb 13, 2016 | 01:59 AM
badcat97's Avatar
Raises some interesting questions on the TC, thanks for that
Old Feb 13, 2016 | 08:15 AM
reb1999's Avatar
Default Pressure regulator valve
Great article on the A8 trans ( same as ZF used in older XK8). The end of the article speaks of the pressure regulator valve or bore which can cause pressure spikes as well as blown ft drum. Symptoms my ZF trans is experience. I've had the fluid changed ( nasty color, overheated, without metal parts or excessive clutch material). the service did wonders for about a month. I've ordered a new special regulator valve for the valve body from Trans Go which boasts will do the repair even with scored valve bore. I plan on full synthetic fluid as the article recommends as well. I'll let you know the results. Rich
Originally Posted by 64vette
This is worth reading. Audi A8 Quattro ZF5HP24 TCC Cycling Bang - Sonnax
Whether or not it relates to your problem, it does show what is involved with a proper approach to troubleshooting, and that approach would be similar I would think.
Old Feb 13, 2016 | 08:25 AM
badcat97's Avatar
These are all great ideas but all the articles and tsb's i have found are for tranny's that are wearing out mine is newly rebuilt with less than a thousand miles on it, my tc is also freshly rebuilt and with jag approved synthetic fluid.
Old Feb 13, 2016 | 10:00 AM
Gus's Avatar
Gus
I would suggest calling ZF they have a web page that you can get the number and ask for tech assistance. Let them know what you had done and your problem and they should be able to help. I had a lot of luck with them.
Gus
www.jagrepair.com
Old Feb 13, 2016 | 10:04 AM
badcat97's Avatar
all they did for me is send me a chart showing what clutches are being used for each gear and when
Old Feb 13, 2016 | 10:38 AM
Gus's Avatar
Gus
Gus
www.jagrepair.com
ianmj
Feb 1, 2016 02:59 PM
MonacoDK
Jan 29, 2016 11:48 AM
XKJoe
Jan 25, 2016 04:49 AM
2001grayjaguar
Jan 25, 2016 12:49 AM
davemac
Jan 13, 2016 10:27 PM
