no power to antenna
Old Jul 11, 2016 | 06:44 PM
dsnyder586's Avatar
Default no power to antenna
Fuse #9 is fine, but no power antenna- I tried a working spare as well.
Ideas?
Old Jul 11, 2016 | 07:31 PM
revauto's Avatar
Do you have a stock or aftermarket radio ?
Old Jul 11, 2016 | 10:39 PM
dsnyder586's Avatar
Stock.
Old Jul 12, 2016 | 07:13 AM
DevonDavid's Avatar
I think that there are two power feeds to the antenna - one through fuse #9 which supplies power to the antenna motor, and a second which comes from the head unit which, I think, energises a circuit with a relay (or two ?) inside the antenna to switch the motor on & off and up & down. This is a green / black wire. If it doesn't work with two antennae - would be worth checking that you have 12volts on this wire too (when the head unit is switched on obviously)
There is also a ground / earth connection which would be worth checking - might have vibrated loose ?
Old Jul 12, 2016 | 12:05 PM
dsnyder586's Avatar
Thanks David-
What colors on the connector am I looking for for ground/power?
Old Jul 12, 2016 | 12:40 PM
DevonDavid's Avatar
Looks like there should be three wires :
1. Brown / Green = 12v + from fuse box.
2. Green / Black = 12v+ from head unit.
3. Black - ground (probably a short wire to a ground stud close to the antenna)
1. must be "always live" - otherwise the antenna wouldn't retract when the ignition was switched off and the key removed because the motor needs power to do that.
Old Jul 17, 2016 | 08:23 PM
wolfpck1's Avatar
had the same issue with my unit finally installed a toggle switch in trunk to a hot wire when ignition is on or can flip it off at car wash etc.
Hex Type
Feb 15, 2022 08:05 PM
dabears06082
Jan 11, 2021 04:51 PM
jagmoust
Jun 20, 2016 06:53 PM
mrplow58
Jun 16, 2016 04:05 AM
cityslang
Jun 13, 2016 09:12 AM
