Noise from left side when cornering left
Old Sep 16, 2011 | 03:17 PM
SteveJacks's Avatar
Default Noise from left side when cornering left
Today I noticed a noise from the driver (left) rear when cornering hard left on my 2004 XK8. I think it sort of sounds like the tire rubbing, but I can’t be sure it really is that. Normally a tire rubbing is fairly obvious, but this isn’t obvious so I am second guessing that.
When turning left, am I correct in thinking that the left side of the car rises a bit? Doesn’t all the inertia of the car go toward the right on a left turn? If so, I would think that if I were to have a tire rubbing problem when turning left, then I would hear it on the right side, where the suspension compresses a bit.
I had new tires put on about 3 weeks ago, and I have not heard this noise until today. The new tires are the stock size; I didn’t go wider or change profile or anything, and I have driven hard since. Trunk is empty as always. Top is down as always. I see no signs of tire rubbing anywhere.
Has anyone else experienced this? Any ideas?
Old Sep 16, 2011 | 09:19 PM
H20boy's Avatar
noises are very hard to diagnose on description, first thing I would do is jack the rear end up (listen on the way up) and look for any signs of your sound. It could just be a squeaky shock. there is also a rubber 'stop' in the upper mount on the rear, it may have degraded and is rubbing a bit inside of the little 'hat' in which it resides. If it really bugs ya, you can get replacement shocks for about $100 ea, and they come with the new rubber piece up top.
Old Sep 16, 2011 | 11:02 PM
Reverend Sam's Avatar
From the left front or left rear?
Old Sep 17, 2011 | 02:14 AM
xenophobe's Avatar
Is it while driving hard and during a turn? Bad wheel bearing?
Old Sep 17, 2011 | 06:05 AM
SteveJacks's Avatar
Left side rear only. And yes, during a hard turn. I thought about the bearing, but I would have thought I would hear the typical roar sound that gets louder as the speed increases.
aholbro1
Dec 29, 2024 06:46 PM
PMKimpton
Aug 3, 2019 08:22 PM
Jay48
Sep 7, 2015 09:30 PM
tberg
Sep 7, 2015 07:32 AM
1100me
Sep 7, 2015 06:26 AM
