Noisy engine when cold
Old May 25, 2010 | 03:42 PM
Skid Mark's Avatar
Default Noisy engine when cold
Hello Everyone!
I have a 2000 XK8 w/106K miles. When cold, if I tap the gas just a little too much, the engine/powertrain makes this whirring, rattling grinding sound off the line, which continues through the shifting until reaching speed. At speed it stops, and after getting completely heat soaked it stops during further shifting and sometimes off the line.
I had the belt replaced and tensioner adjusted a while back and that helped, but alas it has regressed. Had some pulleys replaced w/no effect.
I understand that the XK8 used to come with nylon pulleys, if so would it help to go back to those? If not, what could the problem and solution be?
Thanks!
Russ
Old May 25, 2010 | 04:01 PM
Fraser Mitchell's Avatar
As a 2000 model the exhaust camchain tensioners on each cylinder bank come to mind straightaway. I suggest you take the cam covers off for inspection asap if not before. Engines are wrecked when these let go. If they haven't been replaced, its time to replace them.
Old May 25, 2010 | 04:39 PM
H20boy's Avatar
Redundant thread, see XK8 thread here.
SD96XJ6L
Jan 12, 2022 04:30 AM
cissdm
May 3, 2016 06:02 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
