"Normal" oil consumption
Old Jun 19, 2020 | 12:15 AM
DavidYau's Avatar
Default 99 XK8- no significant oil consumption
In my 99 XK8 NA, I use Liquimoly 10W40 Molygen Synthetic.
No significant drop in dip stick oil level, so no need to add any oil between annual services, even with a very minor oil leak at front of engine (suspect timing cover or main seal).
Old Jun 19, 2020 | 05:24 AM
CorStevens's Avatar
That liquid moly is very interesting stuff. It is used by Amsoil and others to make up for the necessary reductions in Zinc. Some companies, namely Castrol, are working with Titanium nano-particles to achieve similar results.
In your environment probably the biggest risk to the engine and other machined parts is abrasive particle. It would be a good idea to use the absolutely best oil and air filters and make sure that the intake system and other potential air leak risks are fully sealed.
Old Oct 11, 2020 | 08:31 PM
wss25's Avatar
what are the risks with overfill the MAX on the dip stick?
Old Oct 11, 2020 | 08:43 PM
zray's Avatar
a minor overfill on most engines is not an issue. That said, no overfill is ideal. On my car just a few fluid ounces will move the level from “on the dots” perfect to the M or A or X. I would not be comfortable going past the “X”.
PS:
having one of these makes it very easy to drain out a small amount of overfill without making any mess:
Fumoto F106N FN-Series Drain Valve with Long Nipple with Lever Clip
Amazon Amazon
PPS: the risk of a substantial overfill is aeration of oil as the moving crankshaft will churn it into an airy frothy mixture, not ideal for lubrication. Also the possibility of blowing oil seals is substantial.
way too much oil ? Drain it out and have no worries.
Z
Old Oct 12, 2020 | 06:50 AM
wss25's Avatar
Thanks. Will take it back to be drained and filled to a proper level. Now decision is to tow it back or drive it. The overfill is above the MAX and will not go down after three days.
Old Oct 12, 2020 | 10:24 AM
scardini1's Avatar
Keep in mind that when Jaguar increased the oil quantity of our cars, to avoid starvation during cornering, all they did was change the marks on the dip stick. So you’re actually 1 quart closer to over filling the engine with the dip stick showing a normal level. “Never” let your oil go over the max mark. I’m fairly certain that the IPO did this a some point, foamed the oil, and set the stage for that engine’s ultimate demise.
Old Oct 12, 2020 | 05:10 PM
wss25's Avatar
My dip stick is the old model NNE 1723 AA for my 1998 Jaguar XK8 convertible. Can I go to the dealer and get replacement XR 83-6752 - AC at no charge?
Old Oct 12, 2020 | 05:13 PM
  #28
wss25's Avatar
jagtoes
Dec 30, 2019 02:42 PM
rf69
23
Jul 9, 2018 10:49 AM
flyc2c
Nov 1, 2014 10:32 AM
Seth
Sep 2, 2012 07:04 PM
Oldengineer
Jan 3, 2010 08:40 PM
