O2 Sensor Model Numbers
Old Jul 30, 2025 | 01:57 PM
RandyIsntMyName's Avatar
Question O2 Sensor Model Numbers
Hello, going about replacing both upstream O2 sensors after getting P1646 and P1647 codes.
I ordered these which were said to be compatible and look identical, but upon removing the old ones I noticed that the model numbers don't match. Will they still work? I'm hoping one is just an internal code for the same thing.
I know there were several different sensors used across the range, but not sure if they can be distinguished between purely by physical appearance. Old one on the left (D
enso 192400-3100 03U26), new one on the right (Denso Q-E608)
Old Jul 30, 2025 | 06:48 PM
Found another thread that says Denso 192400-3100 is the same part as Denso 234-9016. Denso 234-9016 appears on this site, stating that its the correct sensor.
I'll install them tomorrow.
Old Jul 31, 2025 | 09:37 AM
NorXKR's Avatar
Same cable length? I do not remember parts no, but I got one that had a shorter cable when I changed one on mine
Old Jul 31, 2025 | 04:20 PM
Hell-Cat's Avatar
I replaced my upstream O2s a few days ago with Denso 234-9016, they worked fine.
If the harness connector plugs break on you let me know I have some new ones, though snailmail to Belfast may take a while.
Good luck !
Old Jul 31, 2025 | 07:37 PM
cjd777's Avatar
Replacement of the upper was the 192400 on mine, to my surprise as until I saw it when it came out, I had never heard of it as a replacement. I found it for under a hundred dollars and the 9016 goes from 170 to 300, so someone is getting rich by playing with numbers.
Aleather
May 7, 2025 04:44 PM
Gert Silkin
Jan 28, 2025 06:16 AM
RGPV6S
Jun 26, 2023 03:39 PM
stevep10
Dec 31, 2020 12:06 PM
lossking_
Dec 8, 2020 11:53 AM
