Octopus hose
Old Oct 22, 2021 | 02:52 PM
wymjym's Avatar
Default Octopus hose
Hi,
Is there any reason that I cannot create a replica of the octopus hose out of soft bendable copper, solder all connections, flare ends, dip is some protective urethane and not need to be concerned @ replacing it again?
I plan on keeping the xk8 till I die and hopefully that will be a few more years.
Thanks for your thoughts and insight
wj
Old Oct 22, 2021 | 03:47 PM
RJ237's Avatar
You will still have to use some hose sections to connect to the plastic nipples on the heater valve, pressure tank and throttle body. And don't forget the check valve. Winding it around and bending to get it all to connect would be a challenge. The hose usually lasts at least ten years, so is it really worth doing?
Old Oct 22, 2021 | 03:54 PM
wymjym's Avatar
No it isn't!
thanks for the insight
wj
Old Oct 23, 2021 | 06:09 AM
Jon89's Avatar
Back in late December / early January I cut the leaking passenger-side Norma connector out of the octopus hose and replaced it with a brass hose barb, then replaced the just-beginning-to-weep driver-side T-connector with a new OEM one. The cost of these repairs was about $15 and it completely solved both coolant leak issues. I now expect this revised octopus hose to last for years to come....
Rhonda Hall
Dec 1, 2017 02:26 PM
randyb
Sep 1, 2016 02:08 PM
34by151
Mar 13, 2015 10:27 PM
Dan R
Nov 15, 2014 11:56 PM
Gunz80
Feb 12, 2009 11:47 AM
