Odometer reading is ghosted
Old May 27, 2024 | 08:22 PM
Sacho's Avatar
Default Odometer reading is ghosted
2006 xkr victory edition convertible the odometer is ghosted . Any solutions is appreciated . Thanks.
Old May 30, 2024 | 07:57 PM
Stamford's Avatar
Most likely the bulb that illuminates the message center needs replacing. Since that involves removing the instrument cluster, you may want to consider replacing all the dash bulbs as they will all eventually blow. Not a tough job, but a bit time-consuming,
Old May 30, 2024 | 08:57 PM
Sacho's Avatar
Thanks , is there a procedure for removing the cluster.
Old May 30, 2024 | 09:33 PM
zray's Avatar
It’s been covered several times in the forum. I’d post a link for you if I had it handy. A forum search should be helpful.
XKR-Victory
Apr 18, 2022 09:29 PM
funracer
Jul 26, 2019 09:30 AM
wymjym
Aug 10, 2017 11:48 AM
jagxkrtoofast
Apr 22, 2012 11:25 PM
