Oil cooler radiator AN10?
Old Apr 3, 2025 | 05:11 PM
  #61
JACKP's Avatar
Originally Posted by zray
Probably an apples to oranges analogy, but just throwing it out there : I see a lot of inexpensive cars, primarily Kia’s & Hyundai’s, that have clearcoat and base coat damage. Which has been attributed to sun damage.
There are so many ways to go on this subject. I’m totally uneducated on what factors can contribute to paint damage that I shouldn’t be talking. I’m just glad I haven’t had to deal with it.
Z
I have a 2006 Kia Spectra that sits out in the sun 24/7. The paint on the trunk is in worse shape than the hood. For those in Europe the Boot lid is in worse shape than the Bonnet It could be the way the sun hit one more than the other because of the way it's parked.
Old Apr 4, 2025 | 03:58 AM
  #62
Kuddlesworth's Avatar
I have been an idiot. I have been measuring the core length instead of the overall length, that Setrab radiator is too short to fit the OEm mounts. And I can't for th elife of me find a cooler with a mount that fits. Mount to mount on my OEM cooler is 420mm-421mm long, the matrix is 370mm long.
Old Apr 4, 2025 | 05:40 AM
  #63
JACKP's Avatar
On the Setrab web site they have the dimensions for all their coolers. From best I can tell the Setrab 50-613-7612 6 Series ProLine is an exact fit as far as bolt pattern goes. My XK8 is a 2005. Hope you find one that fits.
Next week I hope to get mine up on the lift and measure clearance for the taller cooler.
Jack
Old Apr 4, 2025 | 05:52 AM
  #64
Jack
The supercharged cars have a larger oil cooler. This is what mine looks like. XKR 2002-2004 ENGINE OIL COOLER #9343
Old Apr 4, 2025 | 05:56 AM
  #65
JACKP's Avatar
As I'm sure you know, if they have one with proper hole spacing you could make some adaptors for height of mounting bracket.
Jack
Old Apr 4, 2025 | 05:58 AM
  #66
Jack
Yea probably just a flat plate with a couple of holes drilled into it will do. Something like this? Buy Mocal Universal Oil Cooler Brackets (Pair) - BRKT1 | Demon Tweeks Not sure why the holes are drilled not in-line with each other though? I take it the rubber mounts you get are just rubber so you can twist it a little to get it to screw in.
Old Apr 4, 2025 | 07:05 AM
  #67
zray's Avatar
Make your own brackets
Z
Rex
Dec 5, 2024 07:10 PM
mouserider
Dec 7, 2022 12:47 AM
Ghostrider
Apr 14, 2017 07:39 PM
randyb
May 29, 2013 03:20 PM
dx3
Apr 16, 2012 09:13 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
