Oil Gallery Plug and RMS
Old Jul 4, 2022 | 05:11 PM
giandanielxk8's Avatar
Default Oil Gallery Plug and RMS
Is it possible to DIY the Oil Gallery Plug and the Rear Main Seal? I only have a jack and jackstands. I do not have a lift.
Will I need any special tools?
Old Jul 4, 2022 | 07:53 PM
motorcarman's Avatar
Gearbox OUT and check the seal. The plug is a 17mm HEX (allen) and is usually loose.
I use a short length of (3"?) PVC schedule 40 or 80 pipe to drive the seal.
I took the seal to the hardware store and got an assortment of PVC fittings for the job.
Old Jul 4, 2022 | 08:30 PM
I see… I have never removed a gearbox before, so that’s a challenge.
I disconnect all the electrics to the gearbox and undo the 16ish bolts of the bellhousing, undo the transmission mount, and use a jack to drop it down? How high off the ground does the car need to be? Is there any seal on the transmission side that should to be replaced?
Old Jul 4, 2022 | 09:16 PM
RJ237's Avatar
I think you need close to 24" clearance to drop it. I have a scissors lift so I am not certain. There are no seals on the transmission to worry about.
Old Jul 4, 2022 | 09:56 PM
Ohh, 24”?! I may need to get creative.
Old Jul 5, 2022 | 06:04 AM
RJ237's Avatar
It's probably not that bad, depends on the height of the jack that will be under the transmission. 18" might be sufficient.
Jay111
Jul 3, 2022 12:27 PM
Stacey H
Nov 16, 2019 05:07 PM
peterv8
Mar 26, 2018 05:20 AM
Salo
Oct 20, 2017 10:17 AM
hawianjim
Aug 29, 2015 07:23 PM
