Oil on plugs, cam/valve cover time and a few maintenance questions
Old Jan 20, 2023 | 07:16 PM
Jtp1984's Avatar
Default Oil on plugs, cam/valve cover time and a few maintenance questions
Just change plugs and all threads were covered in oil. I'm figuring on going to napa in the AM and getting the gaskets for a 00-02 lincoln. I plan on pulling a cover before I head out (to check tensioners) to confirm my belief that it has the old style. It's a 2001 with a vehicle build date of 12/00 but I can not find the engine numbers to check.
can anyone confirm what i assume?
Same year/model tensioners?
anything else I should do/ check while im there?
Now as for the maintenance questions
Do I need a puller to remove wiper arms to get to cabin air filter?
Does anyone know where to get the caps that cover the bolt for the wiper arm?
Is there supposed to be a hose on the second nipple on the coolant resivor near the firewall and where should it lead?
I'm missing 2 bolts to the coil cover where would I find replacements?
and lastly where can if Find (and what is it called) the rubber isolator stand off for the air box?
Sorry to ask so many questions at once but I'm trying to get this thing squared away right the first time after her year plus slumber in my dad's abandoned garage.
Thanks in advanced
Old Jan 20, 2023 | 07:27 PM
RJ237's Avatar
No cabin filter on US cars.
Old Jan 20, 2023 | 08:04 PM
Jtp1984's Avatar
is there a way to retrofit to us models?
Old Jan 21, 2023 | 05:46 AM
Jon89's Avatar
If your car is a convertible, a cabin air filter would be pointless....
The black plastic wiper arm bolt cover caps may still be available at SNG Barratt Group....
No hose on the coolant reservoir's second nozzle of my wife's 2006 XK8 with the 4.2 engine....
Old Jan 21, 2023 | 08:26 AM
motorcarman's Avatar
The INSTRUMOUNT fastener for the air filter box is M6 x 1.00 double ended.(I forget the part number)
Expensive from the dealer but might be found 'after-market'.
Old Jan 21, 2023 | 09:36 AM
MRomanik's Avatar
Veteran: Air Force
I got wiper caps from Ace Hardware many years ago. $2 for 3. I don't remember a stock number. Found them in the hardware section.
Old Jan 21, 2023 | 11:39 AM
Jtp1984's Avatar
sng barret had them I ordered this morning. Thanks though
Old Jan 21, 2023 | 02:49 PM
zray's Avatar
The INSTRUMOUNT fastener for the air filter box are available on eBay for a very reasonable price
don’t have the part number though, sorry.
found these on Amazon
uxcell 20 x 20mm Rubber Mounts,Vibration Isolators,Shock Absorber with M6 x 18mm Studs 4pcs
https://a.co/d/0gzSLO0
Z
chillyp
Feb 26, 2022 08:24 PM
Phil m
Oct 10, 2021 01:07 PM
VivaJag
Feb 10, 2020 05:07 AM
Iconoclast
Dec 14, 2012 09:05 PM
jmniles
Jul 24, 2008 09:02 AM
