Oil Pressure
Old Mar 14, 2018 | 08:36 AM
Spinedoc2304's Avatar
Thanks guys.
I'll be changing the oil and filter tomorrow along with checking the oil pressure sending unit. As an aside, there have been no low pressure indications in the last 24 hours.
Nick
Old Mar 14, 2018 | 08:37 AM
toaster's Avatar
Originally Posted by johns427
Zray, manufacturers specify low viscosity oil for only one reason: CAFE, Corporate Average Fuel Economy, in the States. Low vis synthetic oil adds on average 1 mile per gallon to to fuel economy. His car has 140,000 miles on it. The main and rod bearings probably have increased clearances and may be bleeding off oil pressure at idle. I am suggesting a simple change of viscosity to see if the oil change is the problem.
+1
Old Mar 14, 2018 | 12:50 PM
Gus's Avatar
Gus
You know that I have said over and over again to use the oil recommended for the climate you are in and that information is in your owners manual.
As for the oil filter it may have been the problem with the low pressure indication you got but no way of knowing for sure that the problem no longer exists. I have used non jaguar filters without incident but that is not to say yours is not a problem.
At this point check the lead to the transponder/oil pressure sender switch and if you feel it necessary replace the filter. If you R&R the filter see if you see any plastic wrap or any material that might have obstructed the flow to and from the filter. Just be sure it is clear and clean of any obstructions.
Old Mar 16, 2018 | 08:24 AM
As an update, no low oil pressure readings for the last 2 days.
Haven't done a damn thing to the car yet.
Nick
Qvhk
Jan 1, 2018 10:10 AM
Skid Mark
Feb 5, 2013 10:22 PM
amcdonal86
Mar 1, 2012 10:26 PM
leodog
Jan 4, 2008 06:48 PM
