Allen wrench to secure top
Old Mar 15, 2018 | 07:19 PM
Swallow xk8's Avatar
Default Allen wrench to secure top
Just purchased a 2001 xk8 convertible. I did not get the Allen wrench to lock/unlock top if electrics (?) fail. Also need rubber brake pad. I just need size of wrench and parts houses for rubber parts. Thanks
Old Mar 15, 2018 | 07:29 PM
Welcome to the forum Swallow XK8,
Don't forget that intro in the new members section.
I think the wrench is 8mm, hopefully someone can confirm.
Old Mar 15, 2018 | 08:45 PM
Barry_Tucker's Avatar
Pretty sure that its 8mm but will try to remember to check in the morning
Old Mar 16, 2018 | 09:52 AM
StuG's Avatar
You can get the rubber brake pedal pad from our forum sponsor SNG Barratt USA.
Tell them you are a jaguarforums.com member for a 10% discount.
https://www.sngbarratt.com/us/#!/Eng...8-6799a7a8798f
Cheers,
Stu
Old Mar 16, 2018 | 10:29 AM
avern1's Avatar
Might be a silly question, but did you remove the interior panel in the trunk and look on the hydraulic pump. That is where the key is stored. A lot of folks think it should be in the glove box.
Old Mar 16, 2018 | 10:46 AM
Gus's Avatar
Gus
It is in the trunk at the pump location because you may need to open the petcock on the pump in order the get the latch open / closed.
Colquan1066
Jul 23, 2019 12:15 PM
Atlastajag1
Mar 23, 2018 09:56 PM
Apollo-XJ8
Mar 16, 2018 06:48 AM
MidnghtOwl
Jan 19, 2018 02:25 AM
