Oil pressure gauge
Old Aug 29, 2021 | 11:21 PM
zray's Avatar
Originally Posted by Markmbaha1
The plastic piece “…….The idol also seems to drop too low when releasing the gas. It almost stalls. Where is the adjustment for that?
thanks so much
Mark
I don’t know of an adjustment for the idle per se, only the slack adjustment. Others more knowledgeable than I should chime in.
Z
Old Aug 30, 2021 | 11:03 AM
Markmbaha1's Avatar
Thank you Z. I'll keep checking.
Old Aug 30, 2021 | 04:21 PM
Dr. D's Avatar
The plastic piece the cable goes through comes unscrewed with 2 screws. I unscrewed and rotated the whole holder and bracket to push the cable adjust sheath back toward the firewall. I was in a rush so I think I need a redo. The idol also seems to drop too low when releasing the gas. It almost stalls. Where is the adjustment for that?
thanks so much
Mark
Sounds like you indeed adjusted in the correct direction. I am surprised that the idle is lower. I would have expected a higher idle if any idle change at all.
Is the cable physically tighter now?
Old Aug 30, 2021 | 04:52 PM
Markmbaha1's Avatar
It is but I need to take the intake off so I can see the actual opening position. It's running short on the adjustment. Maybe 3/4 inch left.
Smonop
E type ( XK-E )
Jun 7, 2021 12:11 PM
OrigamiSensei
XJ40 ( XJ81 )
Feb 24, 2018 09:23 PM
Micawber
General Tech Help
Dec 22, 2012 03:36 PM
LouDon
E type ( XK-E )
Sep 29, 2012 02:42 AM
gunnerman
XJ40 ( XJ81 )
Jul 3, 2010 11:43 AM
