Oil pressure gauge off
Old Jul 22, 2016 | 01:45 PM
Pdytat's Avatar
Default Oil pressure gauge off
I have a 98 XK8 where the oil pressure gauge just went off completely to the right. I have no oil pressure light warning and I checked the oil in the engine, which is fine. I replaced the gauge but the same happened with the new gauge, simply no movement in the gauge at all. Any ideas?
Old Jul 22, 2016 | 02:02 PM
WhiteXKR's Avatar
See figure 8.1 here: http://jagrepair.com/images/AutoRepa.../jagxk1998.pdf on the upper right.
Check the 4 wires labeled 'oil pressure' between the main instrument cluster and the minor 3-gauge cluster for an open or a connector pin that may have fallen out.
If all is OK with the wiring, then the problem may be the main instrument cluster that provides the signals that move the stepper motor in the gauge.
BTW, this is a 'fake' gauge, an only moves to 0 and to mid-scale, so it really does not provide any more information than the red idiot light.
aholbro1
Feb 14, 2021 01:51 PM
Sep 17, 2019 09:27 AM
silversurfer1221
Oct 8, 2017 10:08 AM
Dean Kitching
Mar 30, 2016 02:53 PM
Mar 22, 2008 10:38 PM
